9 years agoUnique Memory Initialization Files for Multiple Nios Instances
I want different applications running on multiple instances of a single Nios design. How do I specify unique memory initialization files? (I rather not have two Nios designs and two BSPs, differe...
9 years agoThere is something in your considerations that I can't understood: why do you need multiple instances of nios in your qsys in order to run multiple different applications not simultaneously.
With only one qsys module (that contains only one instance of nios), instantiated in you wrapping top Verilog module you create only one BSP. And with such setup you can run multiple applications flashing them consequently.
