9 years agoUnique Memory Initialization Files for Multiple Nios Instances
I want different applications running on multiple instances of a single Nios design. How do I specify unique memory initialization files? (I rather not have two Nios designs and two BSPs, differe...
9 years agoYour last summary of my intent is correct. I would like to run different applications on two (or more) Nios processors where each processor is an instance of the same Nios design. This way I have only one Qsys project and one BSP.
How do I assign a unique memory initialization file (containing the application ) to each Nios instance? // Verilog example. One Nios design ("nios_cpu") instantiated twice, with each instance running a unique application (how do I assign the .hex file to each?): nios_cpu cpu0 (...); // this one should use cpu0_mem_init.hex (how do I assign this?) nios_cpu cpu1 (...); // this one should use cpu1_mem_init.hex (how do I assign this?) Thanks.
