20 years ago
Unexpected breakpoints
I have recently build up a section of my code, added a task to the system and now I am not able to run the software at all.
The debuger stops every moment on modules like alt_irq_handler and other library modules like there was a breakpoint there, but there is no breakpoint set.
I opened the window with breakpoints and it is empty. I have the tools set to not stop at "main" function but run the code full speed.
What could be the problem here ?
I have tried to build the code with no debugging (option "release" in the compiler settings) and the code has problems running at all. Where to look for the causes ?
I use nios II v6 with micro-C/OS II and latest Nios EDS tools.
    Is there any "break" instruction near the breakpoint?
    Altera's HAL API set many "break" instruction in the APIs in case of unexpected things happen.
    FYI.
    David
    --- Quote Start ---
    originally posted by david_cai@Oct 8 2006, 11:46 PM
    is there any "break" instruction near the breakpoint?
    altera's hal api set many "break" instruction in the apis
    --- Quote End ---
    Does not look like there is any conditional break there...
    First time my program stops, it stops at the SIGTRAP Trace/Breakpoint at the first line (opening brace) of the function alt_irq_handler in the alt_irq_handler.c module.
    So I press green arrow RESUME button, and instantly program stops again, in the same task# 1 at the same line of the code: entry to alt_irq_handler().
    So I press RESUME button again, and the code stps in the same task1 in the function alt_tick of the alt_tick.c module...
    Next time it stops is in the os_core.c module, line 532, and debugger does not find the source file but the function name indicated in the debugger window is OSTimeTick().
    So I press RESUME to have more fun, and my code stops at the entry to alt_tick function again. And then at the OSTimeTick() again, then alt_tick() and so on...
    Looks like each and every system clock tick causes the breakpoint and the code is unusable.
    My "breakpoints" window is empty, no breakpoints set, even no defined & disabled ones...
    Please help! What can I do ?
    How to troubleshoot in such situation ?
    I have found the problem - looks like there was not enough stack size for the new task I have added in the micro-C/OS-II.
    I have increased 1k to 4k and debugger started working fine...
    I had to increase the stack size even above 4k to get the task working as expected.
    Yeah, I guess that you must have enable "Run Time Stack Checking" in the system library properties. So when stack overflow, it will stop at "{". If you wanna know the detailed info, pls look into the Disassembly View when system stop.
    Is there any way of checking peak stack usage (other than inspecting memory)?
