14 years agoUnable to use Nios II/e?
I've been trying to instantiate a Nios II/e core with no success. I am using external SRAM, one 16 bit PIO, and a 50Mhz clock. I am able to synthesize the design, generate the sof file, and con...
14 years agoAnother possible cause using the stock DE0 project example is the PLL. Our build used the legacy pll. There were no warnings from SOPC_Builder (11.0) other than it was being phased out and should be replaced with altpll.
No errors from compiling but lots of warnings, and a compilation that showed no use of PLLs and very little logic in the design. Replacing the PLL with AltPLL fixed it.
