14 years agoUnable to use Nios II/e?
I've been trying to instantiate a Nios II/e core with no success. I am using external SRAM, one 16 bit PIO, and a 50Mhz clock. I am able to synthesize the design, generate the sof file, and con...
14 years agoDammit... turns out the problem wasn't with the hardware or the design.
The /s started giving me problems too. After mucking around, I finally figured out it was a problem with the Nios II EDS. (I'm running Ubuntu 11.10... I've already had to fix a few problems with Quartus on Ubuntu). Invoking nios-download directly from a terminal worked for both /e and /s.
