14 years agoUnable to use Nios II/e?
I've been trying to instantiate a Nios II/e core with no success. I am using external SRAM, one 16 bit PIO, and a 50Mhz clock. I am able to synthesize the design, generate the sof file, and con...
14 years agoAs a final resort, I created a fresh project with just the CPU, on-chip RAM, and a PIO connected to LEDs. I did not constrain the LED I/O pins (to be honest, I don't know how to... yet), but I did constrain the input clock. Other than the LED I/O pins not being constrained, all timing requirements were met.
Same result: /s works, /e does not. I don't remember how I connected the JTAG module. I'll check when I get home.
