14 years agoUnable to use Nios II/e?
I've been trying to instantiate a Nios II/e core with no success. I am using external SRAM, one 16 bit PIO, and a 50Mhz clock. I am able to synthesize the design, generate the sof file, and con...
14 years ago --- Quote Start --- oh I forgot something. Do you have a license for the Nios CPU? If not then you will have to use the *_time_limited.sof file instead of the regular one, and you'll have a window open just after you programmed the FPGA saying you are in evaluation mode. You mustn't close that window or the CPU will stop running. --- Quote End --- No I do not. But as I said, I've already gotten the /s version (which requires a license) to work, albeit time limited/JTAG bound. It's the /e version (which does not require a license) that I can't get working.
