14 years agoUnable to use Nios II/e?
I've been trying to instantiate a Nios II/e core with no success. I am using external SRAM, one 16 bit PIO, and a 50Mhz clock. I am able to synthesize the design, generate the sof file, and con...
14 years agoThanks for your response. I have a few clarifications/questions, though:
Here are things I already checked:- The design compiled successfully
- I used the correct sof file
- The clock pin is assigned correctly and is working (I added a 1 Hz LED "blinker" running off that clock just to be sure)
- Switching to the Nios II/s does work.
