8 years agoUnable to get Nios-II F going, Nios-II S works fine in same config. (DE2-115 + SDRAM)
Hello All, I have a DE2-115 running a Nios-II S(low) with the on board SDRAM (basic config, HELLO WORLD application). 50 Mhz clock, 3ns delay for the ram clock, no FPGA RAM used. When I ch...
8 years agoDear All,
My mistake: You can select 2 different versions of the .sof file to download to the FPGA. The standard version The time limited version. For the /f cpu you need the time limited version in Q lite. And for those of you struggeling with a DE2-115 Nios-II/F. I included a Q17.0 archive of my working project. Best Regards, Johi.
