9 years agoUnable to connect to Arria 10 dev kit board via DS-5
I have an Arria 10 SoC dev kit, and am trying to follow the directions found in the EDS User Guide regarding setting up and debugging bare metal applications. I'm trying to connect via the USB-Blaste...
9 years agoOK...I figured this out myself. I took a look at the python scripts that were failing. Apparently, the debug server listens for connections on port 3010. Well, unfortunately, without configuring to allow this, the McAfee firewall prevents such connections from taking place.
Once I temporarily disabled my firewall, I was able to connect fine. Long term solution will be to configure McAfee firewall to allow these connections from DS-5.
