JEL_W
7 years agoUnable to build .elf file in NIOS eclipse II ,
I am working on FPGA cyclone V DE-10, with quartus LIte version When I build the project on nios II, the ".elf" file is not generated, I've configured the bsp file properties (turn on reduce drive...
JEL_W
7 years agoThank you all ,
the problem is solved ,
I need to increase the onchip memory size .
