8 years agounable to build a program in NIOS II IDE
Hello everyone, I am facing a problem with building a project on NIOS II IDE. I have done a simple program and when i build the project, it shows the following message "make -s all includes...
8 years agoHi Anand Raj Shankar, Johi
First of all, thank you for your help. It is Quartus 9.1 that im using. But with the latest version (quartus 13) i will need even the latest version of Nios II IDE. => Yes, i did just a simple application "bliking a led" with vhdl and it works on the board. => Since i'm a beginner in Nios, i did a simple application " LED lights flashing" given by the developpement Manual NIOS II. So i followed all the steps mentioned on the manual. => Yes, i did it with only onchip RAM. => I tried with debug as Nios II hardware, the problem persists. Thank you. Regards
