8 years agounable to build a program in NIOS II IDE
Hello everyone, I am facing a problem with building a project on NIOS II IDE. I have done a simple program and when i build the project, it shows the following message "make -s all includes...
8 years agoHello Berkoka,
Getting nios up and running can be a real challenge. You do a number of steps in qsys, generate a vhdl / verilog application compile it and download it. And then, hope that it works ... If not it can be really difficult to try. You can have a lot of different causes of problems that make it go wrong so some ideas: => Were you able to build a simple application verilog / vhdl that makes a led blink with your board in quartus? (=> Just to make sure board, communcations, clocks work ? (Test)) => In qsys, make an application with only onchip ram, no SDRAM, SDRAM and SRAM are possible cause of problems. Just the basics. (=> In line with tutorial normally.) => In eclipse, generate application based on hello world small. (based on .sopc) hello world can be too large for some fpga's. => If you start the application in eclispse, click right on the project, and then use debug as Nios II hardware. => Sometimes you can have a problem with timestamp or id, you can check ignore mismatsched timestamp and id if you go to application, right click, debug applications, tab 2. Good Luck, Johi.
