10 years agoUnable to build "*.elf" file in NIOS II Eclipse.
Hi All,
I am novice in NIOS II Eclipse environment. To learn I am using the existing project and after compiling the nios project in Quartus. In order to generate the "*.elf" file, I created new project by pointing to "*nios_cpu.sopcinfo" file and added existing source file to the project. To build the project I am clicking on "build all" but NIOS II Eclipse environment is throwing error (Attached snapshot). console messageinfo: linking test2.elf
nios2-elf-g++ -t'../test2_bsp//linker.x' -msys-crt0='../test2_bsp//obj/hal/src/crt0.o' -msys-lib=hal_bsp -l../test2_bsp/ -wl,-map=test2.map -o0 -g -wall -mno-hw-div -mhw-mul -mno-hw-mulx -o test2.elf obj/default/dbc5cefa7_appl.o obj/default/aoeappl.o obj/default/bootmode.o obj/default/coeappl.o obj/default/db_nioshw.o obj/default/ecataoe.o obj/default/ecatappl.o obj/default/ecatcoe.o obj/default/ecatfoe.o obj/default/ecatslv.o obj/default/foeappl.o obj/default/mailbox.o obj/default/objdef.o obj/default/sdoserv.o -lm
c:/altera/14.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/4.8.3/../../../../../h-x86_64-mingw32/nios2-elf/bin/ld.exe: test2.elf section `.text' will not fit in region `onchip_memory'
c:/altera/14.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/4.8.3/../../../../../h-x86_64-mingw32/nios2-elf/bin/ld.exe: region `onchip_memory' overflowed by 93988 bytes
collect2.exe: error: ld returned 1 exit status
make: *** [test2.elf] error 1
Please help me to resolve the issue. Waiting for your valuable reply. thanks in advance. for your valuable time NRM.
It means exactly what the error message says. Your program is too big to fit into the on-chip memory. Either shrink your program code or enlarge the on-chip memory (if possible).
Hi Galfonz
Thank you very much for your valuable input. I am able to solve the issue by increasing on chip memory. Thanks Neel. - Altera_Forum
--- Quote Start --- It means exactly what the error message says. Your program is too big to fit into the on-chip memory. Either shrink your program code or enlarge the on-chip memory (if possible). --- Quote End --- dear Sir, what we can do if both are not possible 1) to shrink my code 2)enlarge the on-chip memory.
