15 years agoUDP Socket in Niche Stack
Hi Can Any one Help me plz in Niche stack.I want to know that how can we create a udp socket in Nichestack and send data or listen this socket to receive data. Its Urgent.......................
15 years ago --- Quote Start --- on De2 you would have to install uclinux or micro tcp/ip with micro c os2 to create the udp socket.As the de2 board has dm9000 ethernet controller which is not supported by interniche stack. i have done it on de2-115 which have triple speed ethernet which is supported by interniche stack. Regards Hasil86 --- Quote End --- Hi, as you say about triple speed Ethernet, you meant that you selected the Triple Speed Ethernet IP Core under Series Communication in SOPC. Is it right? Does it work as the same chip with DM9000A? Or that is the other chip on specific board? I am using DE2-70 Board, but there is nothing about Triple Speed Ethernet on the Manual Document. Thank you for your help!
