20 years agoUDP Header isn't sent
hi all,
I'm having problems with sending out my udp-header. When I use ethereal it claims that no header was sent out. I am using the LWIP stand alone webserver example to send out my udp messages CODE ******************************************************************** /* * * This file is for testing stand-alone (NO_SYS) LWIP * using a RAM-based simple file system * */ # include "system.h" # include "arch/init.h"# include "lwip/ip_addr.h"# include "lwip/tcpip.h"# include "lwip/udp.h"# include "lwip/netif.h"# include "netif/lan91c111if.h"# include "stdio.h"# include "stdlib.h" # include "sys/alt_alarm.h" /* ---------- IP oriented addresses for ethernet adapter ---------- */# define IPADDR0 169# define IPADDR1 254# define IPADDR2 0# define IPADDR3 2 # define NETMASK0 255# define NETMASK1 255# define NETMASK2 0# define NETMASK3 0 # define GWADDR0 10# define GWADDR1 1# define GWADDR2 1# define GWADDR3 11 int main(void) { //0.6.4 struct netif *netif; struct netif netif; struct ip_addr ipaddr, netmask, gw; struct ip_addr udpDestIpAddr; //IP-address to send UDP packet to struct pbuf* packetBuffer; //Pointer to a packet buffer struct udp_pcb* udpSocket; //Create UDP-socket struct udp_hdr* udpHeader; //Create UDP-header u16_t localPort, destPort; alt_avalon_lan91c111_if* dev_list_ptr = (alt_avalon_lan91c111_if*)alt_ethernet_device_list.next; printf("Example web server using Light-weight IP (LWIP)\n"); printf("and simple RAM-based file system.\n\n"); packetBuffer = pbuf_alloc(PBUF_TRANSPORT,100,PBUF_RAM); /* * Initialize lwip */ lwip_init(); printf ("Setting IP address to: %d.%d.%d.%d\n", IPADDR0, IPADDR1, IPADDR2, IPADDR3); printf ("Setting netmask to: %d.%d.%d.%d\n", NETMASK0, NETMASK1, NETMASK2, NETMASK3); printf ("Setting gateway address to: %d.%d.%d.%d\n", GWADDR0, GWADDR1, GWADDR2, GWADDR3); IP4_ADDR(&ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3); IP4_ADDR(&netmask, NETMASK0, NETMASK1, NETMASK2, NETMASK3); IP4_ADDR(&gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3); //0.6.4 netif = netif_add(&ipaddr, &netmask, &gw, netif_add(&netif, &ipaddr, &netmask, &gw, (void*)dev_list_ptr, lan91c111if_init, ip_input); //0.6.4 netif_set_default(&netif); netif_set_default(&netif); IP4_ADDR(&udpDestIpAddr, 169, 254, 0, 1); udpHeader->src = localPort; udpHeader->dest = destPort; udpSocket = udp_new(); udp_bind(udpSocket, IP_ADDR_ANY, localPort); //Bind socket to port udp_connect(udpSocket, &udpDestIpAddr, destPort); printf("Ready to send....\n"); while(1) { //0.6.4 lan91c111if_service(netif); lan91c111if_service(&netif); udp_send(udpSocket, packetBuffer); printf("Send a package\n"); // printf("Local port is %d\n", udpHeader->dest); } } ******************************************************************** But for some reason, the UDP header isn't sent. Does anyone know what I'm doing wrong?! Cheers, Danny2 Replies
Danny,
I don't think you can bind and connect with the same udp pcb, at the same time. Since you're not really doing anything with it anyway, I would remove the following line of code:
Also, please keep in mind that UDP is "connectionless". Each _send or _recv is a separate transaction. The sockets paradigm hides this from you, but LWIP's raw API requires that you understand this fact and write appropriate code. I posted a sample of how to do this, for a simple echo server. Also, it still disturbs me that you aren't just simply modifying the existing standalone LWIP example. IMHO, you'd make much faster progress going this route. Best of luck, - slackerudp_bind(udpSocket, IP_ADDR_ANY, localPort); //Bind socket to port - Altera_Forum
Hi Slacker,
that is exactly what I am doing. But I got this code from Revolt and for him it seems to be working correctly, so I don't know whats going on... Cheers, Danny
