15 years agoUDP delay to send
Hi, I am using NicheStack with the Altera Cyclone III NiosII Embended Evaluation kit. My application principale is to get measurements and send it each 1ms with UDP_send(). I have done it. ...
15 years ago --- Quote Start --- at 0ms the first UDP message including count=000us at 24ms the second message including count=1000us at 48ms the third message including count=2000us which was acquired at 20ms and so on. --- Quote End --- If timer runs @ 1MHz and you send each 10ms, you should rather have: count=000us, count=10000us, count=20000us Your count values would apply for 1ms send period or a 10us (0.1MHz) timer. Anyway what I asked is how long this process can go on: does it stop after these 3 sends or you can get at time 24*N ms a Nth message including count=1000*N us for any arbitrary N? Or did you find a value for N when the system eventually stops sending frames?
