15 years agoUDP delay to send
I am using NicheStack with the Altera Cyclone III NiosII Embended Evaluation kit. My application principale is to get measurements and send it each 1ms with UDP_send(). I have done it. For try, i setup each 10ms get/send, for about 20 trame sent. I send a counter to have a date (1MHz). With WireShark, i can see that the get measurements is done in good time (counter date), but the effective UDP frame is receive each 24ms. Explain : first at 0.000 count 000376 0.024 count 001376 0.048 count 002376 0.072 count 003376 ... Certainly it is buffered somewhere and i think there is a limit. NIOS Processor i choose is the F at 133MHz (the most on the right) I started from the SampleSocketServer. All the tasks i have written are OSPend() and I use a very short INTerrupt function to give a top each 10ms. The two fonctions INT() and mysendUDP() I've measured 1.5us with oscilloscope. Is there an equivalent Flush() for UDP or TCP Buffer ?
