16 years agouC/OS-III porting
Where can i find uC/OS-III Integration kit for nios2? It's too difficult for me :(
13 years agoMicrium gave me several files which when added to NIOS installed a template for a Hello World MicroOSIII.
After installing them I do have the option to select Hello World MicroOSIII from the New Create from template, however when creating the BSP the make project script bombs out ==> INFO: Creating BSP settings file... INFO: nios2-bsp-create-settings --sopc C:/VSDRRSW/a5gtd7k3_fpga_bup_qsys.sopcinfo --type ucosiii --settings ./settings.bsp --bsp-dir . --script c:/rtn/altera/10.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl --cpu-name cpu INFO: Initializing SOPC project local software IP INFO: [Info] <b>C:/VSDRRSW/*</b> matched 10 files in 0.00 seconds INFO: [Info] <b>C:/VSDRRSW/*/*_sw.tcl</b> matched 2 files in 0.01 seconds INFO: [Info] <b>C:/VSDRRSW/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds INFO: [Info] <b>C:/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds INFO: Finished initializing SOPC project local software IP. Total time taken = 2 seconds INFO: Searching for BSP components with category: driver_element INFO: Searching for BSP components with category: software_package_element INFO: Found Flash Memory: ext_flash for CPU: cpu INFO: Loading drivers from ensemble report. INFO: Finished loading drivers from ensemble report. INFO: Tcl message: "STDIO character device is jtag_uart" INFO: Tcl message: "System timer device is sys_clk_timer" INFO: Tcl message: "Default linker sections mapped to onchip_ram" INFO: Tcl message: "Bootloader located at the reset address." INFO: Tcl message: "Application ELF not allowed to contain code at the reset address." INFO: Tcl message: "The alt_load() facility is disabled." INFO: Default memory regions will not be persisted in BSP Settings File. INFO: Generated file "C:\VSDRRSW\software\HelloOSIII_bsp\settings.bsp" INFO: BSP settings file was created at location "C:\VSDRRSW\software\HelloOSIII_bsp\settings.bsp". INFO: Generating BSP files... INFO: Generating BSP files in "C:\VSDRRSW\software\HelloOSIII_bsp" INFO: Default memory regions will not be persisted in BSP Settings File. INFO: Generated file "C:\VSDRRSW\software\HelloOSIII_bsp\settings.bsp" severe: crt0.s source code not located in installed cpu module driver. severe: crt0.s source code not located in installed cpu module driver. severe: nios2-bsp-create-settings failed. nios2-bsp: nios2-bsp-create-settings failed nios2-bsp ucosiii . C:/VSDRRSW/a5gtd7k3_fpga_bup_qsys.sopcinfo --cpu-name cpu failed I have been bouoncing between the OSII and OSIII scripts and files but cannot seem to locate what is causing this to appear when I create OSIII but not OSII Hello World. Anyone know what is wrong?
