14 years agouclinux_on_NiosII
Hi, I am a beginner for linux os and want to port uClinux on my board. The available hardware on my board is EP3C120F484C7 Cyclone Fpga,256MB SDRAM, EPCS64 Serial flash. According t...
14 years agowhy dont you use nios2gcc-20080203.tar.bz2 from
http://www.alterawiki.com/wiki/binarytoolchain then tar jxf nios2gcc.tar.bz2 -C / The cross gcc tools was expected to be installed in /opt/nios2 dir. But you may install in any other dirs. Then setup the PATH for the cross gcc, you can add a line at the end of file ~/.bash_profile (or ~/.profile on Debian/Ubuntu) ( the file is hidden, you have to use "ls -a" to find it . For "gedit" use open Location, and enter the file name) PATH=$PATH:/opt/nios2/bin I did this my compiler working fine
