14 years agouclinux_on_NiosII
Hi, I am a beginner for linux os and want to port uClinux on my board. The available hardware on my board is EP3C120F484C7 Cyclone Fpga,256MB SDRAM, EPCS64 Serial flash. According t...
14 years agoHi,
I increased gentoo file system image size from 5GB to 10GB. Able to checkout the files with above modification. I am following the Nios2Colinux procedure to implement uClinux on Nios2 Looking for clarification on toolchain build. If I install nios2gcc-20080203.tar.bz2 binary tool chain , is it necessary to build toolchain from the nios2-linux-20100621.tar? I am getting toolchain build error with the nios2-linux-20100621 version. I didn't use patches. is the problem bec of patches or any thing else? regards, Nag
