19 years agouClinux Dist make won't go through
After doing twice make, tried NON_SMP_BUILD=1 make
still won't go through, looks like being lack of romfs, repeated make romfs, won't help. Please suggest, # ##################################################################### ethan@linux:~/uClinux-dist> NON_SMP_BUILD=1 make make -C tools/ucfront make[1]: Entering directory `/home/ethan/uClinux-dist/tools/ucfront' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/home/ethan/uClinux-dist/tools/ucfront' ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++ ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1 no emulation specific options. make[1]: Entering directory `/home/ethan/uClinux-dist/linux-2.6.x' CHK include/nios2_system.h perl -I/home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/ethan/ uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < /home/ethan/ethan/niosII_stratix_1s40/standard/std_1s40.ptf > inclu de/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_ system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp inclu de/nios2_system.h; fi CHK include/linux/version.h CHK include/linux/utsrelease.h CHK include/linux/compile.h /home/ethan/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot ope n '../romfs ../vendors/Altera/nios2nommu/romfs_list' make[2]: *** [usr/initramfs_data.cpio.gz] Error 1 make[1]: *** [usr] Error 2 make[1]: Leaving directory `/home/ethan/uClinux-dist/linux-2.6.x' make: *** [linux] Error 1 ethan@linux:~/uClinux-dist> make make -C tools/ucfront make[1]: Entering directory `/home/ethan/uClinux-dist/tools/ucfront' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/home/ethan/uClinux-dist/tools/ucfront' ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++ ln -sf /home/ethan/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1 no emulation specific options. make[1]: Entering directory `/home/ethan/uClinux-dist/linux-2.6.x' CHK include/nios2_system.h perl -I/home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/ethan/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < /home/ethan/ethan/niosII_stratix_1s40/standard/std_1s40.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi CHK include/linux/version.h CHK include/linux/utsrelease.h CHK include/linux/compile.h /home/ethan/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open '../romfs ../vendors/Altera/nios2nommu/romfs_list' make[2]: *** [usr/initramfs_data.cpio.gz] Error 1 make[1]: *** [usr] Error 2 make[1]: Leaving directory `/home/ethan/uClinux-dist/linux-2.6.x' make: *** [linux] Error 17 Replies
Did you apply the nios2 patches as in the wiki?
the file linux-2.6.x/usr/Makefile need the patch, or you can look at linux-2.6.19 or linux-2.6.20 . - Altera_Forum
TO_BE_DONE
Applied patch uClinux-dist-20070130-nios2-02.diff.gz everything works find, thank you for your time.
Just curious: would all the updates in lower version of patch all included in high version? like uClinux-dist-20070130-nios2-02.diff.gz > uClinux-dist-20060803-nios2-02.diff.gz Cause I need both Ethernet & USB. Maybe can help newbies by explaining the differece usage of all those patchs. I didn't see Changelog of uClinux-dist-20070130-nios2-02.diff.gz - Altera_Forum
These nios2 patches has been submitted to uClinux-dist, and merged. So the last patch was smaller, and just some minor update after the release. Don't use older patches on newer dist release, or it will be over patched.
Well, things have changed now ... nios wiki not working , .. missing links .. :(
Als0 there is not further patch for nios after 2007, Can any 1 tell what is the latest way to download uclinux on ltera DE2 board - Altera_Forum
NIOS Wiki moved to the Altera site:
http://www.alterawiki.com/wiki/linux_for_the_nios_ii_processor (and is not that easy to be found and searched any more:cry:) -Michael - Altera_Forum
Thanks Micheal :)
