19 years agouClinux-dist-20060803 released
uClinux-dist-20060803 had been released for more two months. The greatest news: Nios II arch is included now. !!! http://www.uclinux.org/pub/uclinux/dist/uc...0060803.tar.bz2 (http://www.ucli...
19 years ago --- Quote Start --- originally posted by hippo+oct 26 2006, 01:35 am--><div class='quotetop'>quote (hippo @ oct 26 2006, 01:35 am)</div>
--- quote start ---
<!--quotebegin-nacide@Oct 24 2006, 06:29 PM hippo,
after doing all exactly as stated in the uclinux-dist tutorial, the kernel compiled and a zimage was made but the compile ends with an error.
i dont know what is missing:
/bin/sh: nios2-elf-gcc: command not found
make[3]: entering directory `/home/nios2/uclinux-dist/uclibc'
+ ./extra/scripts/fix_includes.sh -k '~/uclinux-dist-test/linux-2.6.x' -t nios2 -n
the file ~/uclinux-dist-test/linux-2.6.x/makefile or ~/uclinux-dist-test/linux-2.6.x/include/linux/version.h is missing!
perhaps your kernel source is broken?
make[3]: *** [headers] error 1
make[3]: leaving directory `/home/nios2/uclinux-dist/uclibc'
make[2]: *** [uclibc] error 2
make[2]: leaving directory `/home/nios2/uclinux-dist/lib'
make[1]: *** [all] error 2
make[1]: leaving directory `/home/nios2/uclinux-dist/lib'
make: *** [subdirs] error 1
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18868)
--- quote end ---
--- Quote End --- make menuconfig check if you have the correct target? Altera, nios2nommu, and Libc version must be None. Vendor/Product Selection ---> --- Select the Vendor you wish to target (Altera) Vendor --- Select the Product you wish to target (nios2nommu) Altera Products Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [ ] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18918)</div> [/b] --- Quote End --- Hippo, I just tried compilying the new kernel, I applied the patches to it. I also enabled the SMC 91C111 support for my ALtera Development Board. This is what I get when I try to boot up: uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 128 (order: 7, 512 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 14512k/16384k RAM, 0k/0k ROM (1261k kernel code, 453k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) NIOS serial driver version 0.0 ttyS0 (irq = 4) is a builtin NIOS UART RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc91x: not found (-19). TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Cannot open root device "<NULL>" or unknown-block(0,0) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
