15 years agouClinux Busybox build error
Greetings, I have been working to setup a Nios2 uClinux-dist build environment for the past couple of days. I started with the uClinux-dist-20101026.tar.bz2 download from the wiki pages. I th...
14 years agoThanks! This seemed to fix my problem which looked very similar. I an running on fairly new Ubuntu 12.04 install, but I think I had seen similar problems in the past while building on an Ubuntu 10.10.
I was getting the same error cited above. Oddly enough, though, the error did not appear every time. I think when I used my own .config files, I avoided this problem, possibly because I was excluded certain parts of the build. In any case, it would be good if this package requirements were added to the Wiki if they aren't already.
