15 years agouClinux Busybox build error
Greetings, I have been working to setup a Nios2 uClinux-dist build environment for the past couple of days. I started with the uClinux-dist-20101026.tar.bz2 download from the wiki pages. I th...
15 years agogood tip aprado......
it seems to me to be lack dependencies to build the kernel.......... after you install all dependencies first try to compile with defalt all settings at menuconfig good luck
