15 years agouClinux Busybox build error
Greetings, I have been working to setup a Nios2 uClinux-dist build environment for the past couple of days. I started with the uClinux-dist-20101026.tar.bz2 download from the wiki pages. I th...
15 years agoNice, take a look at this article: http://www.alterawiki.com/wiki/install_nios_ii_linux
sudo apt-get install git-core git-gui make gcc ncurses-dev bison flex gawk \ gettext ccache zlib1g-dev libx11-dev texinfo liblzo2-dev pax-utils uboot-mkimage corkscrew You need those libs t compile everything. Cheers
