9 years agoUBIFS size issue
Hello, I am working with UBIFS, When I am giving 55MiB of vol size, by following command ubimkvol /dev/ubi0 -N vol -s 55MiB I could able to see only, 49 MiB of space when Kernel b...
9 years agoHello,
Thanks for reply, I went through the links, it has mentioned about the free space i.e. "Use%" from below logs . It also informs that how it varies. Following logs of mine is showing the same. But I actually want to know that , when I create a volume by 55 MiB size and I get it as 49 MiB size after df -h, then for what purpose 6 MiB (55MiB - 49MiB) is used ? Why I could not able to see 55 MiB size, as allocated total space. ? -- Following is the log ----- root@dhcppc7:~# df -h Filesystem Size Used Available Use% Mounted on ubi0:vol_1 49.2M 44.0M 5.2M 90% / root@dhcppc7:~# sync root@dhcppc7:~# df -h Filesystem Size Used Available Use% Mounted on ubi0:vol_1 49.2M 43.0M 6.2M 87% / ------------------------------------------------------ Thank you, Ashwin Rase.
