10 years agoUART Test ISSUE (LOOPBACk)
hi,
I am using Altera Quartus 10.1 SP1, NIOS SBT 10.1 SP1 and ModelSim Altera Starter Edition 6.6D. I am trying to implement UART in SOPC and write a NIOS sample code and test it using ModelSim. I built SOPC using UART, NIOS and Memory and generated sopcinfo files. After that created ELF by using this sopcinfo and launched in modelsim. What ever i print on console is reflecting on TXD line and i tried to loopback TXD to RXd but i unable to see any data in RXD Buffer[Serial to parallel converter]. Data is available on RXD line. Is there any other setting i need to do in order to test Loopback UART??? Please help in testing of UART LoopBack.3 Replies
Hi, which FPGA are you using? I am using the Cyclone V SoC and trying to assign the UART_RX and UART_TX signals to "special function" pins, but I am unable to do so.
I have used the UART with the Cyclone V Terasic development board and it works fine. I have to find my files.
If you look in the UART code created (by SOPC builder / QSYS) you might find there are two transmitters one is the real transmitter and the other is a stimulus source for rxd. You can go in and hack the connection to connect txd and rxd:-
Have a look for some lines like this:- // assign source_rxd = rxd; and uncomment to become assign source_rxd = rxd; and also find the stimulus_transmitter and disconnect the txd output so change from .txd (source_rxd) to .txd ()
