9 years agoUART 16550 vs standard UART
Hi all, is there a simple way of replacing the standard UART, which is in all examples, with the UART16550? I mean, that simply all stdin/stdout/stderr goes to the UART16550? I can only have o...
9 years agoHi,
I suspect you observed "none" in the settings due to the Qsys generated files are not refreshed/synced with your SBT. Try reload the .sopcinfo file and create new BSP. You do not have to rename as the settings should reflect the name in Qsys.
