9 years agoUART 16550 vs standard UART
Hi all, is there a simple way of replacing the standard UART, which is in all examples, with the UART16550? I mean, that simply all stdin/stdout/stderr goes to the UART16550? I can only have o...
9 years agoHi all,
just tried to get the 16550 UART to work at all, but no output so far. I tried to implement, what is in the the "ug_embedded_ip" manual, but so far no luck. Is there anything obvious missing, or wrong: # include <stdio.h> # include <stdlib.h> # include <sys/ioctl.h> # include <sys/termios.h> # include <fcntl.h> # include <string.h> # include <unistd.h> # include <sys/time.h> # include <time.h> # include "system.h" # include "altera_16550_uart.h" # include "altera_16550_uart_regs.h" # define BUFSIZE 512 char TXMessage[BUFSIZE] = "Hello World, UART16550 sending\n"; int UARTDefaultConfig(UartConfig *Config) { Config->stop_bit = STOPB_1; Config->parity_bit = NO_PARITY; Config->data_bit = CS_8; Config->baudrate = BR115200; Config->fifo_mode = 0; Config->hwfc = 0; Config->rx_fifo_level= RXFULL; Config->tx_fifo_level= TXEMPTY; return 0; } int UARTBaudRateTest() { UartConfig *UART0_Config = malloc(1*sizeof(UartConfig)); altera_16550_uart_state* uart_0; uart_0 = altera_16550_uart_open ("/dev/a_16550_uart_0"); UARTDefaultConfig(UART0_Config); altera_16550_uart_write(uart_0, &TXMessage, strlen(TXMessage), 0); usleep(1000); free(UART0_Config); return (0); } int main() { int result=0; result = UARTBaudRateTest(); } Thanks!
