20 years agou-boot and zImage
Following the hippo's buildroot, I got the zImage file. In the other side, I have u-boot working from flash memory. Now, I am wondering if that's possible to download the zImage directly with u-boot.9 Replies
--- Quote Start --- originally posted by mfm@May 8 2006, 02:31 AM hi,following the hippo's buildroot, i got the zimage file.
in the other side, i have u-boot working from flash memory.
now, i am wondering if that's possible to download the zimage directly with u-boot.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15157)
--- quote end ---
--- Quote End --- use tftp boot.
--- Quote Start --- originally posted by hippo+may 8 2006, 03:16 am--><div class='quotetop'>quote (hippo @ may 8 2006, 03:16 am)</div>--- quote start ---
<!--quotebegin-mfm@May 8 2006, 02:31 AM hi,
--- quote end ---
--- Quote End --- use tftp boot. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15164)</div> [/b] --- Quote End --- Here I'm talking about if I had to mkimage zImage or not.
TO_BE_DONE
--- Quote Start --- originally posted by hippo+may 8 2006, 03:57 am--><div class='quotetop'>quote (hippo @ may 8 2006, 03:57 am)</div>--- quote start ---
--- quote start ---
originally posted by mfm@may 8 2006, 09:46 am
--- quote start ---
--- quote end ---
--- Quote End --- use tftp boot. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15164)</div> [/b] --- Quote End --- Here I'm talking about if I have to mkimage zImage or not. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15166)</div> [/b] --- Quote End --- You'd better write your questions more clearly. I misunderstand so many times. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Don't mkimage, it is already compressed. You should not want to write the zImage to flash with u-boot, either. Put your zImage file in /tftpboot of your tftp server, and use, tftpboot [loadAddress] zImage where loadAddress is (your sdram address + boot link offset( default to 0x00800000) ) <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15169)</div> [/b] --- Quote End --- Well, what I'm trying to do is to program the flash with the kernel via u-boot, and since u-boot deals with the .img files so I guess I got to transform the zImage with mkimage before downloading it with tftpboot.
TO_BE_DONE
<div class='quotetop'>QUOTE </div>
--- Quote Start --- Why do you program the flash with u-boot? It is not the right way. Use the nios2-flash-programmer to program the flash.[/b] --- Quote End --- Cause I want to work only on linux and don't have the linux version for altera stuff (I'm not going to reboot linux -windows all the time). Besides, I want to through that usb-blaster http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- You should use u-boot to download program via tftp to sdram and run. That should be most people want u-boot to do.[/b] --- Quote End --- And if I can do all that things with u-boot only, why bothering myself with other tools ! - Altera_Forum
You can download it, and program it in ram, but you can't boot it using bootm. The 'bootm' command requires a valid u-boot image. > Don't mkimage zImage, it is already compressed. Compression has absolutely _nothing_ to do with mkimage. The mkimage utility is necessary to properly boot a kernel image using u-boot, regardless of whether or not the kernel is compressed. mkimage simply adds (prepends) a header to the kernel (or filesystem, or script, etc). The header contains information such as load address, entrypoint address, a header CRC-32, data CRC-32, and yes ... a field that indicates if the data (the kernel) is compressed. When the kernel is compressed via the kernel build scripts, you should tell mkimage that kernel has compression 'None'. > I guess I got to transform the zImage with mkimage before downloading it > with tftpboot. Correct. > Why do you program the flash with u-boot? It is not the right way. Use the > nios2-flash-programmer to program the flash Don't be silly! Programming flash with u-boot is one of its most useful features. It is perfectly appropriate (and correct) to do so -- especially when you do not want to require xxxBlaster and an exposed JTAG header. Additionally, if you load your flash image using TFTP, it is _much_, _much_ faster. Furthermore, u-boot has been programming flash memory on more architectures for a _much_ longer time than the "flash-programmer". > You should use u-boot to download program via tftp to sdram and run. That > should be most people want u-boot to do. I have been working with u-boot for for well over 7 years now. I've done at least a dozen board ports using four different architectures. I can tell you from experience, _most_ systems use u-boot to boot a kernel that is stored in flash. The TFTP feature is used to perform field upgrades (and for testing during development). > And if I can do all that things with u-boot only, why bothering myself with > other tools ! Exactly! With u-boot you can do almost everything using something as primitive as a UART interface and some cheap terminal software. Or as sophisticated as loading and executing a script via NFS, that in turn loads a kernel image via tftp that gets loaded into flash and eventually booted ... phew ;-) Regards, --Scott - Altera_Forum
Scott,
Thanks a lot. Now I learned more about u-boot. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Could you give some sample scripts for daily usage of u-boot? Do you use dhcp and nfs -root ? Best regards, Hippo - Altera_Forum
Hi Scott,
thanks a lot, that's really instructive http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
