    Hi scott,
    Here is another issue...now.....i got an error message.....kernel panic....
    debian-dell-p3:~# kermit -c
    Connecting to /dev/ttyS0, speed 115200
    Escape character: Ctrl-\ (ASCII 28, FS): enabled
    Type the escape character followed by C to get back,
    or followed by ? to see other options.
    Using MAC Address 00:07:FFFFFFED:0C:04:FFFFFFBD
    host 10.0.0.1 is alive
    DK1S40 ==> bdinfo
    mem start = 0x01000000
    mem size = 0x01000000
    flash start = 0x00000000
    flash size = 0x00800000
    flash offset= 0x00000000
    sram start = 0x02000000
    sram size = 0x00100000
    ethaddr = 00:07:ED:0C:04:BD
    ip_addr = 10.0.0.51
    baudrate = 115200 bps
    DK1S40 ==> setenv bootfile /tftpboot/uImage
    DK1S40 ==> printenv
    baudrate=115200
    ethaddr=00:07:ed:0c:04:bd
    ipaddr=10.0.0.51
    serverip=10.0.0.1
    netmask=255.0.0.0
    stdin=serial
    stdout=serial
    stderr=serial
    bootfile=/tftpboot/uImage
    Environment size: 162/65532 bytes
    DK1S40 ==> setenv bootargs root=/opt/nios2development rw nfsroot=10.0.0.1:/tftpboot/10.0.0.51
    DK1S40 ==> printenv
    baudrate=115200
    ipaddr=10.0.0.51
    serverip=10.0.0.1
    netmask=255.0.0.0
    stdin=serial
    stdout=serial
    stderr=serial
    bootargs=root=/opt/nios2development rw nfsroot=10.0.0.1:/tftpboot/10.0.0.51
    Environment size: 238/65532 bytes
    DK1S40 ==> saveenv
    Saving Environment to Flash...
    Un-Protected 1 sectors
    Erasing Flash...
    Erased 1 sectors
    Writing to Flash... done
    Protected 1 sectors
    DK1S40 ==> tftpboot 1100000 uImage
    TFTP from server 10.0.0.1; our IP address is 10.0.0.51
    Filename 'uImage'.
    Load address: 0x1100000
    Loading:# ################################################################
    done
    Bytes transferred = 715524 (aeb04 hex)
    DK1S40 ==> imi 1100000
    # # Checking Image at 01100000 ...
    Image Name: Linux Kernel Image
    Image Type: Nios-II Linux Kernel Image (gzip compressed)
    Data Size: 715460 Bytes = 698.7 kB
    Load Address: 01000000
    Entry Point: 01000000
    Verifying Checksum ... OK
    DK1S40 ==> bootm 1100000# # Booting image at 01100000 ...
    Uncompressing Kernel Image ... OK
    Linux version 2.6.11-uc0-barco1 (root@debian-dell-p3) (gcc version 3.4.3 (Barco Control Rooms))# 2 Sat Jul 2 11:40:34 EDT 2005
    uClinux/Nios II
    Altera Nios II support © 2004 Microtronix Datacom Ltd.
    Built 1 zonelists
    Kernel command line: CONSOLE=/dev/ttyS0 noinitrd ip=bootp root=/dev/nfs rw
    PID hash table entries: 128 (order: 7, 2048 bytes)
    Console: colour dummy device 80x25
    Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Memory available: 14464k/16384k RAM, 0k/0k ROM (1524k kernel code, 215k data)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    NET: Registered protocol family 16
    devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
    devfs: devfs_debug: 0x0
    devfs: boot_options: 0x1
    NIOS serial driver version 0.0
    ttyS0 (irq = 4) is a builtin NIOS UART
    io scheduler noop registered
    io scheduler cfq registered
    smc_probe: 50000 Khz Nios
    SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
    eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0c:04:bd
    NET: Registered protocol family 2
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    NET: Registered protocol family 17
    eth0:PHY 100BaseT
    eth0:PHY Full Duplex
    Sending BOOTP requests . OK
    IP-Config: Got BOOTP answer from 10.0.0.1, my address is 10.0.0.51
    IP-Config: Complete:
    device=eth0, addr=10.0.0.51, mask=255.0.0.0, gw=10.0.0.1,
    host=nios2, domain=nios2.net, nis-domain=(none),
    bootserver=10.0.0.1, rootserver=10.0.0.1, rootpath=/opt/nios2development
    Looking up port of RPC 100003/2 on 10.0.0.1
    Looking up port of RPC 100005/1 on 10.0.0.1
    VFS: Mounted root (nfs filesystem).
    mount_devfs_fs(): unable to mount devfs, err: -2
    Freeing unused kernel memory: 68k freed (0x1190000 - 0x11a0000)
    Warning: unable to open an initial console.
    Kernel panic - not syncing: No init found. Try passing init= option to kernel.
    Any idea....???
    Hi haq,
    > Any idea....???
    Yes, you need a root file system with init -- but now you have a working u-boot ... which
    is good thing ;-)
    The bootargs are _not_ passed to the kernel since the uClinux port does not support passing the command line
    or board info structure into the kernel from a boot loader ... so you'll have to set your command line during
    kernel config.
    --Scott
