14 years agoTutorial for C/C++ programming
Hi, I wanted to know how to use C or C++ with my FPGA. I already know those languages but i have no idea how to use them to control my hardware. I know that there is a file called "system.h"...
14 years agoall right I answer as far as I can.
- set_pio_irq_mask I don't know what is this function. but I know what does it do. this function sets value on the address of PIO. http://www.altera.com/literature/ug/ug_embedded_ip.pdf (page 10-7) it masks which IO should / should not be enable for interrupt. for example 0x01 is set, which means bit0 of PIO is enable as interrupt pin. - set_pio_edge_cap this function set if the interrupt should be LEVEL interrupt or edge captured interrupt. if it set 0 which means this interrupt is LEVLE interrupt ( I'm not sure if it is opposed). - alt_irq_register I'm sure you can find document. http://www.altera.com/literature/hb/nios2/n2sw_nii52010.pdf (on page 14-40) register the interrupt on your system. and specify function which is called when the interrupt is occurred. is that answer what you want?
