15 years agoTSE with SGDMA in Loopback
Hi folks, i try to write a driver with the SGDMA and TSE. I checked the hardware design with the simple socket server example and the LWIP example, both worked so far. I also tried out the S...
15 years agoHi Micio82,
for the working driver i also use an tcp/ip stack(embosIP) and an operating system(embOS) from the Segger company. Due to their regulations i'm not allowed to send this stuff to the public. But what might help you is the light weight tcp/ip stack with an altera driver (lwip). You should have a look to this thread http://www.alteraforum.com/forum/showthread.php?p=93638#post93638 and here you can get the driver http://lwip.wikia.com/wiki/available_device_drivers#lwip_1.3.2 this driver example helped me a lot, hope it does the same for you. If i find a little time, i might also copy some stuff together and post it here, but at the moment we have an urgent project. Greeting, Oberon
