15 years agoTSE_MAC and memory
Hi Guys, I've been building on examples and built a functioning ethernet. I can use the Nios for TCP TX/RX and i have interfaced some HDL for direct UDP TX. I'm currently developing on a...
15 years agoHi AsValdr,
Exactly the same as me, the sgdma wait for receive the descriptor chain. Are you using SOPC or QSYS ? I don't know why there is a problem with the descriptor. Maybe a problem with the connnection with the on-chip memory of the descriptor ? Can you tell me if you it works if you re-add the sram controller like the original project ? I don't If there is some people from Altera in this forum ? Maybe some other developpers can test the same thing and tell us if it work or not ? Thanks. ps: I debug the sgdma and see that the descriptor chain is not receiv.
