15 years agoTSE_MAC and memory
Hi Guys, I've been building on examples and built a functioning ethernet. I can use the Nios for TCP TX/RX and i have interfaced some HDL for direct UDP TX. I'm currently developing on a...
15 years agoHi,
I've got the same problems and get stuck at the same as you. But I found something. I use too SSS exemple and I've seen that, if I made any change in Qsys the software don't work and get stuck at [tse_mac_init] INFO : TSE MAC 0 found at address 0x0c042000 INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED In debug mode make a break and where you are exactly stuck. Maybe it's like me. But I succed to use the design without external memory. Don't make any change at the @ in qsys and do not delete anything or component in qsys. It is my own experiment maybe you don't have the same things.
