15 years agoTSE MAC and marvell phy 88e1111 troubleshooting
Hi ,all I am using development tools:Quartus II 10.1,Nios IDE 10.1.Hardware :Arria II GX, EP2AGX260FF35I5N. I am using TSE MAC and the tools described above,and a custom board with the device...
15 years agoGot the board partially working.It turned out that incorrect clock was supplied to GTX_CLK .
The problem i am running into right now is as follows: - I am able to ping the board about 10-15 minutes past initialization.At that period of time,I am able to ping most of the packets correctly.The ping requests which are timed out are ICMP replies which are corrupt (failed checksum) ( I am able to see that in Wireshark). -After that time is passed (10-15 minutes),I am receiving ping requests ,but the board does not reply (Probable cause is that the frame ,which includes ethernet,ip and icmp , that is received is corrupted,as I can see on debug that icmp_input () callback function is not entered). What could be the problem and how can It be solved? Thank You.
