16 years ago
TSE Ethernet MAC and uClinux
i have a custom design with the Altera TSE. All
works fine, but the uclinux do not load the driver. In the jtag console i see nothing. No Probe from atse.c will be done. Is there any trick to say the linux kernel to probe the atse?
The Kernel is configured with the Experimental TSE. It compiles correct.
Thanx
Marco
Here is the bootscreen: (You will see a ifconfig and the result: No such device)
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.30 (brinker@brinker-notebook) (gcc version 3.4.6)# 863 PREEMPT
 Thu May 6 09:36:53 CEST 2010
uClinux/Nios II
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 16256
Kernel command line:
NR_IRQS:32
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 60248k/4704k RAM, 0k/0k ROM (2591k kernel code, 2113k data)
Calibrating delay loop... 48.74 BogoMIPS (lpj=243712)
Mount-cache hash table entries: 512
net_namespace: 264 bytes
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NTFS driver 2.1.29 .
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered (default)
fb0: Altera FB frame buffer device
ttyJ0 at MMIO 0x4001890 (irq = 6) is a Altera JTAG UART
console  enabled
Driver 'sd' needs updating - please use bus_type methods
physmap platform flash device: 01000000 at 00000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000020000 : "Bootloader"
0x000000020000-0x000000320000 : "Linux"
0x000000320000-0x000001000000 : "User-Disk"
physmap-flash.0: failed to claim resource 0
m25p80 spi0.0: m25p16 (2048 Kbytes)
Creating 1 MTD partitions on "m25p80":
0x000000000000-0x000000200000 : "epcs16-fpga_configuration"
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: irq 11, io mem 0x040018c0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd:   ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd:   INTL:   16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd:   ATL :   32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd:   USED/FREE:   3968       128
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 11
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Freeing unused kernel memory: 1600k freed (0x8308000 - 0x8497000)
hub 1-0:1.0: over-current change on port 2
Shell invoked to run file: /etc/rc
Command:
Command: hostname MiniQuadrix_II
Command: mount -t proc proc /proc -o noexec,nosuid,nodev
Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev
Command: mount -t devpts devpts /dev/pts -o noexec,nosuid
Command: mount -t usbfs none /proc/bus/usb
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: mkdir /mnt/userdisk
Command:
Command:
Command: /bin/mount -t jffs2 /dev/mtdblock2 /mnt/userdisk -n
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0000: 0x7095 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0004: 0x141c in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0008: 0x3890 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a000c: 0x5335 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0010: 0x2999 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0014: 0x14cd in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0018: 0x384a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a001c: 0x178e in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0020: 0x3843 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0024: 0xc232 in
stead
Further such events for this erase block will not be printed
Command:
Command: ifconfig eth0 192.168.1.2
ifconfig: SIOCSIFADDR: No such device
Command:
Command: /mnt/userdisk/etc/post_init.rc
Shell invoked to run file: /mnt/userdisk/etc/post_init.rc
Command:
Command:
Command:
Command:
Command:
Execution Finished, Exiting
Command:
Command:
Command:
Command:
Command:
Command:
Command:
MiniQuadrix_II login: [A
    problem solved. I have just to update my nios2-dist.
    Marco
    Hi
    how did you mananage to make the tse eperimental.. I have tried compiling but it give me lot of errors..
