14 years agoTSE_Driver Architecture
Dear Friends, In TSE Software Driver Architecture (ug_Ethernet), there is a Memory Block at the bottom of page 141 ( ug_Ethernet page 141), Is this is External memory, or Packet memory o...
14 years ago --- Quote Start --- This memory block is not part of TSE itself. It is the memory device available in your system: sdram, sram or onchip memory. --- Quote End --- Thanking you for your reply. It mean this is external to TSE , Is packet loss accure if Processor NIOS-II/f received high speed packets?. or in other way how do i increase the processor speed?. or NIOS-II/f had sufficient speed to handle all incoming packets? NIOS-II/f having system clock is 125Mhz regards kaushal
