9 years ago
Trouble with setting up Ethernet
Hello, guys!
I am a beginner on learning FPGA,
recently my professor ask my to transmit the data from the FPGA to a LAN or internet via ethernet, and I am deeply troubled by this
First, I try to follow the tutorial on "Using Triple-Speed Ethernet
on DE2-115 Boards"
However I found out that it also needs to use NIOS II, however, I already use it for computation purpose before. I want the data transmission and the computation to process at the same time.
Is there any way that I can do this let NIOS execute two different codes at the same time?
Also, I found out that instead of storing the code in SDRAM, the tutorial store the code in "Altera Monitor Program" - on chip memory,
will it infer any conflicts?
I also thought about build two nios on the system, is this possible?
Thanks!
