20 years agoTristate Bridge Problem
I have component sram_0 (16 bits width) and flash_0 (8 bits width) share a tristate bridge data bus.
How can I assign both tri_state_bridge_0_data to both components' data bus during instantiation using VHDL? If i write tri_state_bridge_0_data(7 downto 0)=>fl_dq and tri_state_bridge_0_data (15 downto 0) =>sram_dq(15 downto 0) it wil generate compiling error..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif1 Reply
You can use the SOPC build your tri_bridge design.
Using SRAM and CFI IP core, will output FL_CS_n , FL_RD_n , FL_WR_n , SRAM_CS_n , SRAM_RD_n ,and SRAM_WR_n . RD_n <= FL_RD_n and SRAM_RD_n ; WR_n <= FL_WR_n and SRAM_WR_n ; You can try! --- Quote Start --- originally posted by kwchiet@Aug 26 2006, 09:30 AM i have component sram_0 (16 bits width) and flash_0 (8 bits width) share a tristate bridge data bus.how can i assign both tri_state_bridge_0_data to both components' data bus
during instantiation using vhdl?
if i write tri_state_bridge_0_data(7 DOWNTO 0)=>FL_DQ[/b] and tri_state_bridge_0_data (15 downto 0) =>sram_dq(15 downto 0) it wil generate compiling error..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17865) --- Quote End --- [/b] --- Quote End ---
