15 years agoTriple Speed Ethernet Qsys connections
I need to connect a TSE component to NiosII in Qsys and am confused as to which AvalonST adapter(s) to use. Can someone please provide an example? I have a custom board, but right now I'm tryi...
15 years agoSimply, if You don't add particular component in QSYS, then those components are not enabled in BSP options and are not defined in system.h file.
This is very common when You don't add flash or use the different name than in example. I usually use my own network settings file without flash, because it is used only for mac address and web files in web server example.
