DChen45
7 years agoTriple Speed Ethernet not working
Hi all, I am working on the TSE currently. I generated the IP and configured it to RGMII. I am providing all clk signals 125MHz with a pll. And I did the following configuration (same as the genera...
DChen45
7 years agoHi Dlim,
Sorry I was not explaining clearly. I am using Altera Cyclone V and Quartus 15.1.
I generated the TSE IP and generated the example design at the last step of the IP.
I ran the simulation for the example in Modelsim and everything worked fine.
Then I created my design and tested it on hardware.
I set the all the configurations as the example in my design. But I got the problem I described earlier.
Hope you can help!
Leon
