DChen45
7 years agoTriple Speed Ethernet not working
Hi all, I am working on the TSE currently. I generated the IP and configured it to RGMII. I am providing all clk signals 125MHz with a pll. And I did the following configuration (same as the genera...
Deshi_Intel
7 years agoHi Leon,
It seems like you are trying to bring up TSE IP by referencing to certain example design but it's not working.
May I know which FPGA that you are using and which example design that you refer to ?
Just to confirm you are running simulation and not hardware testing right ?
Have you tried to verify the example design instead of your own design ? Then you can compare the difference and it may lead to the actual root cause.
dlim
