20 years ago
Timestamp timer problem
Hi ,
I am having some problems in using the timestamp timer. Basically , when i am measuring the time to perform a single instruction, i occasionally(but not always) get a negative answer.I have taken care to call alt_timestamp_start() whenever I use the timer, to ensure that it does not overflow.
Also when i don't change the program and run it again, each time i get a slightly different number for the number of cycles taken. What could be the reason?
My code is as follows :
//CODE
if(alt_timestamp_start() < 0)
printf("Timer init failed \n");
exit(0);
time1 = alt_timestamp();
time2 = alt_timestamp();
timer_overhead = time2 - time1;
printf("\n timer overhead is %d",timer_overhead);
*(peripheral_base ) = 0x210f1007
printf("\n time to perform 1 write to hw is %d" ,(time2 - time1 - timer_overhead));
printf("\n time1 is %lu",time1);
printf("\n time2 is %lu",time2);
//END OF CODE
I get the following output :
//OUTPUT
timer overhead is 246
time to perform 1 write to hw is -12
time1 is 143
time2 is 377
//END OF OUTPUT
Any suggestions ? Am i missing out something ?
Karthik
    you have to turn on bit31 of the address to uncache the io port access.
    or use IORW macro.
    feynyan :
    you have this problem but otherwise you can read value returned by
    al_timestamp() funciont.
    In my case this function returns always 0
    I cannot understand why
    Do you have some idea?
    ciao
    walter
    You need to start the timestamp first.
    Also the timestamp doesn't roll over, so if it has reached its maximum value it needs to be started again.
