14 years agoTime-limited OpenCore Plus cores problem
Hi, I am new to nios2.I am using cyclone 2 fpga starter board ( I am using Quartus2 web edition ).I have tried design example given in the manual of nios2.I was able to complie and simulate my de...
14 years agoHi,
Thank you very much. you saved my life :).It is working after changing the processor type to nios 'e'. I was able to flash my processor design to FPGA chip but the bad thing is I cannot flash my c code into the nios processor system.I have compiled the code and when I tried to run it as nios2 hardware,I can see the jtag connected in target connections tab but I am getting error message "connected system ID hash not found on target at expected base address". I tried with ignoring mismatched system id (I have searched about this error in forum and one guy sugested to do so) but I am getting one more error "Downloading ELF Process failed". Do you have any idea about this error. Thank you in advance Sarat
