14 years agoTime-limited OpenCore Plus cores problem
Hi, I am new to nios2.I am using cyclone 2 fpga starter board ( I am using Quartus2 web edition ).I have tried design example given in the manual of nios2.I was able to complie and simulate my de...
14 years agoWhen you switched to the 'e' core there should have been a non-time limited .sof file generated. Sort your directory by file type and make sure there isn't a more recent .sof file that isn't time limited.
What are you using to download the .sof file? The Quartus II programmer or configure-sof from the command line? If it is the latter try the QII programmer instead since I'm not sure how the nag message is supposed to behave if you download using the command line.
