19 years agoTightly coupled memory and C2H
I have a NIOS application for which using tightly coupled, on-chip memory appears to be offering a nice performance boost. I have a large array of values that I like to reference periodically and ra...
19 years agoI've never tried that before but it should work. Be sure to dual port the tightly coupled memory and use a connection pragma so that C2H masters the 2nd memory port. By definition tightly coupled memory ports must be a 1:1 connection with a tightly coupled Nios II master. So that means you can't have C2H accessing the same memory port that the Nios II tightly coupled master connects to.
Nios II <---------------------->Port s1 of the dual port memory (read latency 1) C2H (using pragmas) <----->Port s2 of the dual port memory (read latency of 1 or 2) By the way, if some of you are wondering how to eliminate some of the overhead of calling the C2H generated hardware accelerator, this is one method since you don't have to flush the data cache (assuming this is all the shared memory your accelerator needs to access). I hope that helps, JCJB
