14 years agoThe problem of the DasUBoot !
4. configure and build, make clean make my_nios2_config make ==================================== I've set, "export CROSS_COMPILE=nios2-linux-uclibc- " In u-boot dir, put my_nios2.h in include/configs/, put my_nios2_fpga.h in board/altera/nios2-generic/. Then add an entry my_nios2 to the NIOS2_GENERIC list,like this: " # include "../board/altera/nios2-generic/my_nios2_fpga.h" /* fpga parameters */ # define CONFIG_BOARD_NAME "my_nios2" /* custom board name */ " Why does the command not work ? [root@localhost u-boot]# make clean [root@localhost u-boot]# make my_nios2_config make: *** No rule to make target `my_nios2_config'. Stop. [root@localhost u-boot]# make clean [root@localhost u-boot]# make my_nios2 make: *** No rule to make target `my_nios2'. Stop. THANKS !
What does these mean ?
1. add an target entry to the file boards.cfg in u-boot directory after the line containing nios2-generic, like this my_nios2, nios2-generic nios2 nios2 nios2-generic altera my_nios2 nios2 nios2 nios2-generic altera Means to set the new file named boards.cfg,and modify the info of the " nios2-generic nios2 nios2 nios2-generic altera my_nios2 nios2 nios2 nios2-generic altera" into it???????????????????????????? =========================================================== http://www.alterawiki.com/wiki/guide_to_3c120_with_u-boot in u-boot dir, put 3C120.h in include/configs/, put 3c120_fpga.h in board/altera/nios2-generic/. Then add an entry 3C120 to the NIOS2_GENERIC list in Makefile. make 3C120_config =========================================================== http://www.alterawiki.com/wiki/extrem_guide_to_kill_neek_with_u-boot in u-boot dir, put NEEK.h in include/configs/, put neek_ocm_spi_mmu.h in board/altera/nios2-generic/. Then add an entry NEEK to the NIOS2_GENERIC list in Makefile. make NEEK_config =========================================================== http://www.alterawiki.com/wiki/guide_to_2c35_cf_with_u-boot in u-boot dir, put 2C35.h in include/configs/, put 2c35_cf.h in board/altera/nios2-generic/. Then add an entry 2C35 to the NIOS2_GENERIC list in Makefile. make 2C35_config Why did I do this above,it show me error ? - Altera_Forum
1. add an target entry to the file boards.cfg in u-boot directory after the line containing nios2-generic, like this my_nios2, nios2-generic nios2 nios2 nios2-generic altera my_nios2 nios2 nios2 nios2-generic altera Means to add the "my_nios2" into all the file including the "nios2-generic" in the u-boot folder~! MAKE IT!gaga~
