8 years ago
The L4 Watchdog Module Address Map is not exact in the hps.h
I would like to use header in my application using Altera Cyclone V.
In the Cyclone V Hard Processor System Technical Reference Manual I can find this information about the Watchdog:
Registers in the L4 Watchdog module
Module Instance Base Address
l4wd0 0xFFD02000
l4wd1 0xFFD03000
But in the following header file the address does not correspond:
7 816:# define ALT_L4WD0_OFST 0xffd00200
7 859:# define ALT_L4WD1_OFST 0xffd00300
Is that the good header file?
What can I do?
Thanks for your help
Jerome
    I'm not sure why you are seeing different values, but It should be like
    @6546:# define ALT_L4WD0_OFST        0xffd02000
    @6589:# define ALT_L4WD1_OFST        0xffd03000
    I have checked the file from the "Quartus installation directory\ip\FreeRTOSv10.0.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\Altera_Code\HardwareLibrary\include\socal\hps.h"
    If you are facing the same issue try reinstalling Quartus.
    Let me know if you need any further assistance.
    Anand Raj Shankar
